TH-X00/TR-X00/E-MU Teak/Denon biodynamic general discussion
Shit I’m seeing mahogany going for $500 sometimes on eBay so $400 for ebony is a good deal imo. Nice guy on here sold them to me.
$400 for the Ebony is a fantastic deal! I paid almost 700 for mine new on EBay.
That’s awesome!
Are you thinking of modding them? :blush:
Not sure yet. Wanna hear them first. They come Monday.
[quote=“PapaEmeritus, post:302, topic:6178”]
[/quote]ouch! :grimacing:
Yesterday I got an TH-X00 Ebony for 300 euros in very good conditions…
If I don’t like the pads I’ll probably get these Perforated Sheepskin Replacement Ear Pads Compatible with Fostex TH-600 TH-610 TH-900/900MK2 FOSTEX T50/T40/T20RP, E-MU Teak, Massdrop TH-X00 and TR-X00 and Some ZMF Headphones (Sheepskin Leather) https://www.amazon.com/dp/B07X2F29B2/ref=cm_sw_r_cp_api_i_spUwEbFW52QMG
@PapaEmeritus told me about the accessory house pads.
Can I use the attenuation ring with the accessory house pads and still have a close to stock sound?
They also came with a set of dekoni pads and a balanced cable. I probably won’t use either. If I like them I’ll get a hart cable.
I don’t recommend those pads. Those are the ZMF Aeolus pads. The non-perf are much better suited to the X00. Just my 2 cents.
This is all personal opinion and it boils down to how sensitive you are to treble. The non-perf accessory house pads will increase the sound stage but will probably increase the treble. The Lawton mod smooths that treble out. It can’t hurt to get some attenuation rings and a few different pads and customize the TR-X00 to your tastes tho. Happy modding!
And be sure to post some pics of your new headphones!
Oh OK. I’ll look for those.
And thanks for the help. I’ll try some different options. Just always looking for a good place to start. Thanks again!
Have it change the Sound signature after the Lawton cups?
What for Stage you have choise it?
Oh, are all the divers the same (mahogany, ebony, purpleheart)? So basically the Lawton mod is the same for all the tr-x00?
Yes, the sound signature changes with the lawton cups. They are about twice the size of the stock cups. Depending on the wood you choose, you can select a wood that compliments your preferences.
Sorry, can’t understand this question.
Yes. All the drivers in all the TR-X00 headphones are the same. The different wood cups are the only difference.
Ok, I thought so. So anyone interested in Lawton mod should just get the mahogany (easy to find). Thanks again!
Think he might be asking what level lawton mod did you go for?
No no the Stage from the Cups i mean in his towel.
The Mahagony are not so good in Bass as the Ph or Ebony.Better in mid,and the highs are sometime too much.
When you find a Denon Ah d2000 is the same from the Driver.
Same People say it is the best Phone in Bass and middle as the Fostex.
But People say many things.:wink:
