Why is it hard to find it on Amazon?
Thereâs an issue with fakes going on, labled as ampire or something, you just gotta be careful
Is this still the go to budget dac?
probably if you can find a real one.
pretty much. schiit , monoprice, and jds labs refuse to release theirs so topping gets all the money
Does it have multiple outputs? To a darkvoice and a pa3 is what Iâm hoping to do
You would need y adapters but usually splitting a line level signal isnât an issue.
I heard the D30 is a little better than the D10 and not that much more $
I use a splitter on mine to a liquid spark and pa3 and works fine
on paper measurements wise they perform almost identical the d10 has better build quality and has a cool screen as well as is cheaper. unfirtunately right now you run the risk of getting a fake so I always reccomend people buy form amazon s if they recieve a fake its an easy return
well they seem to be out of stock a lot on the d10
Itâs too bad the d30 didnt have the outputs I need but as it stands the d10 will be fine for me
Amazon.ca has some
what is it missing?
yeah a high demand dac that basically has no competition rigt now
This is what i was hoping for but a y split will work
How does the Modi 3 and Khadas tone board compare to this? Theyâre a lil more expensive but at least theyâre in stock and not easily counterfeit.
modi 3 is audibly worse and khadas tone board measures better but is extra money just for a case.
-SMSL M100
-SMSL Sanskrit 10th
-Khadas Tone Board
All 100$ ![]()
I wouldnât consider a modi whatsoever until schiit brings them up to the same standers as their new products imo
Did anyone else order one from massdrop this last time and if so, do you have any updates as to when or if it will ship?
