No, I havenāt touched it since it works just fine
Just to clarify because Iām still a bit confused, were the initial modes that shipped stuck in flipped absolute phase, or did they release a firmware update that does this?
I donāt know how Schiit solved that back then.
maybe it was software related.
As it is with topping, I do not know exactly whether they solve this with the software.
What would be possible.
Iām also not sure if it affects every device or is sporadic, apparently two batches are affected.
Maybe can help this Information.
This unit retails for $189.00, plus tax in Canada. Right now on CAM, there is a guy in B.C. asking $150.00 for an E30.
DSD64 = Patched.
Reverse polarity = patched too, but USB only. No ways to patch optical / coax.
So if you can switch from USB to coax/optical easily, itās a good way to know if you hear the difference between āreverse polarityā and normal.
But you probably wonāt.
Aoshida-HIFI Audio Store on Aliexpress has confirmed their stock of E30 has serial number starting from 2004 which has polarity issue fixed. Just ordered one.
-Audiophiles talking about reverse polarity in a DAC.
-Me enjoying music through a stereo tube buffer with one left tube āmessingā with the left channel and one right tube āmessingā with the right channel: Youāll get over it.
Re stacking. Does the e30 run: cool, warm, hot?
If you are talking about temperatures and not sound signature, I canāt feel any heat coming from mine really at all. It is on top of my Asgard 3 and there is maybe a slight tinge of heat, but definitely not warm or hot.
Does the Asgard 3 run hot enough to potentially damage the rubber feet on dacs? My dac is small and my desk space is limited so the only thing i can do is have on the Asgard.
I donāt think it would. Itās just a nice warm temp.
@Blu Thanks.
I donāt think so, no. It gets hot, but it doesnāt get hot enough to melt things I donāt think. I have the DAC on the part of the AMP where there is the least amount of heat possible though.
Any canucks trolling around on here? and gotten one of these? Trying to order from amazon but will not let me use PO Box for delivery(or any canada post outlet)ā¦will it ship to a home address or just wonāt ship to Canada period?
Cheers
God I want an Asgard
It definitely gets a recommendation from me if you want a warmer sounding amp. I love this thing.
Iād buy it on eBay.
Thx. I had tried po box on there as well and didnāt work. Managed to use a buddies town address though
. Now just the 1 month wait for it to arrive.
What wall wart do you guys recommend for the Topping e30 and does it really matter which one I should buy?
Hello,
A simply Smartphone charger doing his job or a good solid power bank.
Otherwise maybe a good solution i think is this Card here from Kitsune Hifi who are not bad.But i didnāt tested it myself but i think is a good thing when would use on the Pc.Only need a free space on the Pc when you have.Is only for the Power connection,not transporting Data.
https://kitsunehifi.com/product/elfidelity-axf-100-ultra-iii-usb-isolator-audio-filter-for-pc/
