Well do you know if the Zen DAC has the sound you are looking for?
From what I can tell it seems like a great piece of hardware with lots of options.
Part of my problem is I donāt quite know exactly what it is Iām looking for specifically.
The solid state amps Iāve had are:
FX-Audio DAC-X6
FiiO A3
xDuoo XD-05
Tubes:
Little Bear B4
xDuoo TA-10
I must admit, Iāve LOVED my tubes. If anything, a bit more then any of the solid states Iāve owned. So⦠yeah. Not sure exactly what I want to dive into next. Both solutions should do what Iād like.
Ah so I would assume you are looking for something very warm and colored sounding then, if you like tubes. I think ifi is known for having a pretty warm and colored sound. The Hip DAC is supposedly super colored.
True, Iāve heard that. However, Iāve also looked into it, and found that Iām not as interested. Doesnāt quite feel right. Then again, in this situation, it just so happens to be higher among the list of things that could fit my needs but doesnāt feel quite right.
Whatever you like and want most, I think itās all about having fun.
iāll probably buy either a zendac (its small enough for my bedroom) or an xduoo-05 since i might not need MQA since i might move back to spotify⦠but i dont think the xduoo can be used without draining the battery
It can, you just have to make sure itās plugged in like you would be charging it. How it handles it past that, I donāt know.
It seems like it wonāt since it uses 2 different usb ports for power and data
I just want to use it nonstop on my laptop
I mean how it routes the power. Itās like with a UPS, itāll handle power in one of two ways:
- The battery is charged before simply passing through power
Or - The battery is under constant strain, being discharged to feed whatever is plugged into it while receiving a charge itself (these tend not to last as long for obvious reasons)
Darkvoiceās big brother La Figaro 339i (latest revision) is up on Drop. So temptedā¦
I havenāt played video games in what feels like ages because I just donāt have the time. But now I have so much time because of Corona that I bought a Nintendo Switch Lite out of curiosity.
Niceeee, really curious to see what you think
Me too. It will be a while.
How long before you start rolling tubes, lol
I had a couple of hybrid amps and didnāt really get anything out of rolling.
My newish tube amp is still in its virgin state.
On the smaller side, I ordered a driver tune up kit from Lawton Audio for my Fostex TH-610ās.
Topping e30 arrived while my wife and I were eating dinner. Got it hooked up and it sounds great. I ordered it Tuesday of last week and it arrived from China todayā¦quick turnaround. Majorly impressed with Apos Audio.
Very affordable!
