how do they sound?
20
I don’t have them yet so I will go off of memory (although it has been a while). So they are actually pretty amp dependent and will change a fair bit from the amp and source. Overall it’s got a more relaxed signature that is warm but ends up not really being bassy which is kinda strange. Not as wide sounding as you think, and honestly reminds me of the timbre of a planar at times. It’s a strange headphone, just make sure you have a good amp. Personally at 500 bucks I don’t know if I would buy them, but at the 300 range I would for sure. It’s just something different, kinda like how the nighthawks have a fairly unique signature (although they don’t sound like the nighthawks)
So it is a given that I recently bought the BLON BL03s and the Topping NX3s, the next ones that I will buy soon are the Spinfit ear tips. As much as I love the Comply foams the durability of those are my main concern about it and 2 pairs have already broken down, and I have heard good things about Spinfit so far.
I got a pair of Spinfits from 11/11 sale and immediately switched back to my foam tips. If you like foam tips, I don’t think spinfits are the fix.
If you still want to try them, I would size down. They were larger than I thought.
I can switch to foam tips but Comply is just too expensive for me and also the fact that the durability issue from those makes me not want to get those. for now, I will give the Spinfits a try and to see how it will be helpful for me.
Sucks x2… I still mostly use them as they fit me best and are super comfortable…INAIRS AIR2’s are a tad cheaper and the next best fit and comfort wise for me :+1:
if only there are like foam tips that are durable, maybe there is but I am not just looking hard enough and I am not sure if there is even an INAIRS here.
I like the Campfire Audio Marshmallow Foams they have been holding up well for me
Half sized equipment rack should be arriving soon, i had a friend send me something from his IT shop, I’ve let this get completely out of hand…
I knew I would see you back here soon… Welcome back
See you again in this thread
I hope spinfits work for you. They just felt like a more expensive version of stock tips to me. New Bees ended up working well and they are cheap enough to stock load on them.
My Topping MX3 arrived already..
Got this today, finally. Cannot wait on what difference can make it for me in terms of sounds.
Not exactly audio, but bought two tickets for Tampere Rockfest for 350 bucks :smiley:
Ordered long time ago but finally arrived.
And some INAIR and Okuli foam tips.
The INAIR are very sticky, but the Okuli match my ears better.
These are my first foam tips, seal is definitely better than silicone, curious how long they last.
Let us know what you think of it using it on day to day basis.
oh cool man!! sound like fun. go out there and moshpit lol
nice, i just used banana plugs for the first time ever and it was so nice. It’s like these should be the standard for any audio system! instead of splitting speaker wire and making sure the ends make contact with the system
THAT is dope. Looks like high quality build and hopefully sound as well.
Keep us posted!
