It’s ok and usable
me neither… will get another one(hartaudiocables)for the Ananda and keep my oidio on the Elegia
I got one to try out since it was cheap. They are more firm than iem cables. It has that plastic coating that iems have near the connector, but all the way down the cable.
Exactly - 10 charcters
Consider cutting some foam to size and stuffing it in side the backside between the pads and the adapter ring to add more bass and bit more soundstage. You can also remove the felt lining on the inside of the grills which also opens them up a tad more. This is how I have my pair setup. Also yes it takes a little while to break in the pads but once they are the comfort is pretty good
This is what I’m trying to do right now to try and break them in quickly. No idea if it’ll work, but hell, something is better then nothing.
I bought the xduoo xd-05 plus but I hear buzzing from it when using my iems. Anybody else have this problem? Great amp though with headphones
What iems are you using, and what gain setting?
Just picked up a liquid platinum on Amazon, it was on sale and I’m weak willed…
Using the blons at the lowest gain setting
There will be hiss with some iems, so you could get an impedance adapter. Is it very prominent?
No but it is kinda weird since I can’t hear any hissing from any other amp/dacs I have. Its not really buzzing tho it’s more like interference of some sort
What other amps do you have? The xd05 may have hiss with more sensitive iems with the power it’s got on tap, so it can be somewhat unavoidable
Ya that makes sense. Still an awesome day/amp tho. Blows my old micca origen + out of the water
What input are you using?
Please post your thoughts and what kind of headphones you are using with it.
Latest, should be here on Monday :slight_smile:
Nice, hope you enjoy them :+1:
Mine arrived with the USB cable. Interesting to hear what you think about it.
My craving for these just came back… :grimacing:
Using the USB in. Haven’t tried the spdif since I don’t have any spdif sources. When I use aux in the buzzing stops tho
