Kennerton Stor. Kennerton variation of the Fischer Audio Fa 011. I think only 25 were made.
should have it this weekend gonna use it to play around with some op amps as I already slapped a Burson V5i in my XD05 basic and loved it
if anyone has recs feel free to let me know I ordered a couple I saw people recâd that I could find and a couple randos
(but if its over $40 Iâll probably just get another V5i instead lol)
Well after ordering my own Xinhs cable and now finally able to see it in person, it really is a good cable, soft and thick as well. Might get an another pair for my other IEMs such as my Tin T3 Plus, for that needs a cable upgrade because the stock cable of those are not really that good, itâs okay but not great.
Both a Kato and a Chu. I am not remotely a fan of Moondropâs marketing or vibe (lonely jerks), and I only enjoy their tuning fairly decently so far, but it will help me to get a grasp of what they sound like for making comparisons etc.
Second-hand so itâs not like Iâm throwing any coin their way anyway.
grabbed a pair of ety ER2SE off CAM for half their going rate price.
any suggestions on how to clean / sterilize used IEMs without damaging them accidentally?
q-tip and some rubbing alcohol should be fine
some more stuff!
a bunch of 1:66 aircraft models from Osborn Model Kits: https://www.osbornmodelkits.com/
Avro Arrow
DHC-3 Otter
DHC-3 Turbo Otter
DHC-1 Chipmunk Trainer
Canadair CT 114 Tutor Trainer
North American Harvard MK IV Trainer
I want to get a few more, but later:
DHC-2 Beaver
DHC-2 Beaver Water Bomber
Canadair CL-215 Water Bomber
Two small packages.
The bigger package was a box of foam. Literally. Fresh foam for my Beautiful Audio pads. The crushed yellow pads are the three year old originals.
AndâŚmore Hart gear. I finally caved on a cable for my Cascades and I wanted a longer cable so I was looking for a longer connector. Turns out you can just buy an extension cable. I bought a 12" cable. I have got to take a pic of all the Hart gear that I have. ![]()
Koss KPH30i
Well, f#$% me sideways! These are pretty incredible for the price ![]()
I couldnât helped myself, so I had to hear it for myself to see how it improved from the Koss KPH30i, I must say from first impressions, it did sound-wise to me. Also finally, detachable cable, though I would have preferred an MMCX detachable cable per side, but itâs fine enough and I âborrowedâ the Yaxi pads from my KSC75 to put it on my KPH40s.
This is a steal right now for the price. I blame some people here who got me into Koss, goddammit.
I think this kind of detachable cable is totally okay. Mmcx is literally the worst
It really depends, but I can see why you can say it is that for it can be a pain in the ass to remove. But as for me, I never had any issues with MMCX other than the one I have mentioned, most of the time they work fine enough for me to live with them with no problems.
youâre saying the KPH40i sounds better than the KPH30i?
Yes and no. Yes itâs because of its easily removable drivers like the KSC75, more easy to replace the stock pads with Yaxi pads even though the stock pads are already soft enough for comfort at least for me and the removable cable-ish and of it being flat and better than the KPH30iâs cable. The No would be the sound for itâs basically a remastered KPH30i in my opinion but the sounds is completely subjective to each userâs preference. Itâs like this, the KPH30i just let the music do the talking and cater to that musicâs highlights, while the KPH40 has a tuning that pretty much you cannot go wrong with it for it caters to most peopleâs ears.
In my opinion though, itâs better as well sound-wise objectively, though if you prefer the KPH30iâs treble sparkle and mids, you might want to keep your KPH30i, because they are a bit tame on the KPH40, but just right enough that the sparkle is still there but in a more chill tone.
New Main monitor GIGABYTE M32U 32"
i after finnally getting my hands on a GPU (3070TI) i decided to treat myself and buy a new screen, overall both in person and on paper looks great, 4k with 144Hz and good overall color accuracy
nice 40 series is rumored to be a early release though, hoping to finally upgrade from my 1070 so I can properly run newer games
I wouldnât count on the 40 series at least for the first couple of months from launch, its probabbly going to get price gouged to all hell.
Anyway there is âa method to the madnessâ basiclly the idea is upgrading with minimal value loss
i normally upgrade a few months before the ânext genâ for two main reasons:
- The prices of current gen are at their lowest, and i can also declare them as a business expnese
- You can still flip your hardware for at least 60-70% of the new hardware price.
In this case i bought my 3070TI for 700$+Shipping and Taxes (800$ total), sold my 2070 Super for 480$. Also buying new means i can list it as a business expense so that softens the blow even further.
And with the 40 series coming out, expect prices from those to be goddamned high again, and to be honest this is the perfect chance right now to get a GPU within reasonable price.
well if they are releasing early (nvidia usually releases in the winter) it most likely means production is ahead of schedule (so it should be a better launch than the 30 series)
Bet youâre running better then my 570 is. Been eyeballing a 3060ti.
