Is there a SE output in the V281?
Yup. Two of them.
But not only for balanced 1/4mm I guess? High end and Low end?
I havenât played with it much as I used the XLR balanced out or the right, but they are both stereo 6.3mm.
Per manual:
The right jack has its own dedicated amplifier for an in-phase stereo signal.
The left jack is connected to the 180° phase shifted signal.
I totally agree. I was planning to list my Aeolus as it lost out in my routine, but its nice to listen to on SS. I havenât given time to the Auteur on this amp yet, but I have I feeling I might continue prefer that one on tubes.
How would you describe the Violectric sound? is it analytical or more laid back?
@Antpage2 maybe this helps you getting an idea, as I remember you know the compared amp in the video
Thatâs a great photo.
Aeolus is a looker
I really like this grill over the other versions. Great photo
Those are SO gorgeous!
Current status of my order is sanding and finishing. Canât wait for the Aeolus to arrive!
Any pro tips on pads to order with the Aeolus?
Originally I was going to just get stock Aeolus but now Iâve decided to get uni suede perf as well. Any other worthwhile standouts?
I can only rec suede, they are the best re comfort and the sound is great.
I use Perf Suede on my Aeolus, but the stock Pads are good aswell.
Iâve enjoyed the stock aeolus pads and universe leather pads on a tube amp, and the universe suede more on SS amps. Those are the three I can vouch for sounding good on the aeolus. I also find the leather pads far more comfortable than the suede, personally. I did try the verite leather on them, but it was just too neutral then, wasnât a fan.
Damn gorgeous set in that reviewâŠfrickin Beautiful!!
