my ears roll off between 13k-14k… ![]()
It’s normal if you are older, not really something to worry about, as your brain will make up for it lol
Ok so, I checked online the BLON BL-03s costs indeed $38 here in my country and I get it via delivery from China. But I think I am going to have to pass on this one for now since I just got the KZ ZS10 Pro after all.
Don’t get hooked on buying chifi lol, you will end up with like 30-40 cheaper pairs when you could have had like 4 high end pairs (unless you are a quantity over quality type of person)
I will try to, also I have other stuff to buy besides these ones after all.
Tripowin does provide balance I’ve got a 4.4mm mmcx cable
Which is a good thing because QDC is reverse polarity so it would be out of phase.
You might want to invest in an MMCX to 2pin converter or vice-versa, if you are happy with your cables or if you have enough for all your gear.
took a gamble on 2pin 2.5mm cable of tripowin c8, hope it gets the job done
I heard some things that the cable of the BL-03s are not that good? If so it might be a good idea to get some like replacement cables for it though it will cost you more than $38. But oh well an improvement of an IEM that you love is sometimes necessary to give it a bit more of an individuality.
Cable is ok, you can live with it until you can get a replacement. It is cheap, but ofc useable.
I’m waiting on this one.
That is good to know and yeah Yinyoo is good, though I got to wonder what is the difference of an 8 core and a 16 core cable though for I only have 2 eight cores for T2s and ZS10 Pros.
Does anybody have a suggestion for cheap replacement tips? It is hard to justify 20 dollars for tips on a budget IEM.
Tips can make or break an iem, so it’s worth trying a few out as the results will vary from person to person, spending a few extra bucks on tips that fit, lockdown and seal is well worth it imo.
Could start here?..New Bee foam tips
What would be the overal better choice in terms of sound quality, the Blon 03 or the KZ ZS 10 pro?
I got the zs10 pro first before I got the blons. I found the highs to be on the harsh side with some songs. The blons are never sharp and overall just sound better to me in every way, and they’re cheaper too. I returned the zs10 pros and kept the blons. I will admit however that the zs10 pros had an overall better fit than the blons for me. But the sound is more important to me. I got the blons fitting good finally.
Alright thanks for your response, after reading some reviews i guess more people prefer the blons. Do you know what size of eartips i can buy for it?
I used the 4.9mm dekoni tips
PM me I can send you a pair of Dekoni Samples.
