KIWI EARS KE4 REVIEW:
SOUND:
The Kiwi Ear KE4s are one of my new favourites under $200. At mid volume they are very smooth, relaxing, and warm-leaning with a full low-end. Perfect for chilling and a non-fatiguing listen as the vocals are laid back with a good sense of space and noteweight…But the real magic happens once you crank these up because the KE4 also scales very well, not quite Explorer levels, but just as immersive, and it’s how I would recommend them to be listened to.
SCALING & VOCALS
Once you crank these up the KE4s become more all-rounded, and less laid back, almost like it woke up from a slumber. The vocals that were pushed back at mid-volume now moves closer without being in your face as you hear the details better in both the uppermids and treble. The bass also gets thumpier, it becomes more prominent, hitting deeper, and the KE4 goes from warm-leaning to a more bassy sound that also has a natural vocal and treble presentation that isn’t buried.
Normally with scaling everything becomes more forward because of the increased volume, and usually that’s where the issue happens with some vocal fatigue or treble sharpness. But because there’s a scoop at 1K, this pushes the vocals back and gives the KE4 a sense of distance making the vocals feel not shoved in your face, but also still feel extended enough because of the 3K boost that’s also less than harman which means it’s not shouty as well.
So what you end up getting are vocals that are non-fatiguing, but still extended and open at high volume, which is difficult to balance, so bravo to kiwiears on that. However, the vocals still aren’t perfect, if you’re looking for more power and intensity and that deep vibrato, then that’s where the KE4 falls short on. Even though the vocals are extended with good note-weight, they can still feel a bit weak since in order to strike that balance at both mid and higher volumes, some trade-off needs to happen, and in this case, it’s in the power department.
2DD ISOBARIC BASS
But the good news is that the dual isobaric dynamic drivers gives the KE4 one of the best low-end under $200 when it comes to the texture, impact, and noteweight. It makes the overall tuning sound full and grounded and doesn’t feel overly airy or light, and kickdrums especially hits very deep followed by a nice rumble in the sub.
TREBLE & TECHNICAL PERFORMANCE
The separation and imaging is good, and it’s what is expected at its price, but when you compare it to the planars the KE4 isn’t quite as fast in its transients and sharpness. In-terms of pure detail retrieval and technical performance both the Supermix4 and Canta would be the better value in that sense, as well as similar all-rounders like the Nova, Chopin, and Quintet.
Although the trade off is in-return for a slower pacing you do get better slam, heavier noteweight, and more natural timbre, and personally I would take the KE4’s bass over something like the 2024 S12 that is evidently quicker, but not as enjoyable musically. Treble wise the KE4 is pretty balanced overall, it’s not exciting or jumps out, but it’s also not dark or hidden in the background. There’s no timbre issues when it comes to the BAs, it’s not overly airy or sizzly, not sharp, nor super smooth, it’s kind of just solid treble, it does its job.
vs KIWI EARS Quintet, Orchestra Lite, Canta
Now, versus the Quintet and Orchestra Lite both of those will have better detail, imaging, and separation, and just overall more technical than the KE4. The Orchestra Lite is going to be the cleanest and most neutral of the bunch, it’s vanilla and balanced, very inoffensive if that’s your vibe, the low-end isn’t nearly as good as the KE4, but they are more complete vocal wise because it’s not scooped in the 1K.
Even the cheaper Canta is more detailed when it comes to the treble, and also cleaner in the separation, but both the Canta and the Quintet have a little bit of that planar timbre to them on top of their extra treble, which can get a bit much, and not as natural timbre wise. And in-terms of the low-end texture, slam, noteweight, and overall musicality the KE4 to me is much more enjoyable, and with scaling they’re just so much more immersive.But I will say if you listen at mid-volume then those other 3 kiwis are going to better and more well-rounded.
vs SUPERMIX4
Now, versus the Supermix4 these 2 are total opposites, the SM4 is cleaner, quicker in it’s low-end with more forward vocals, and more lively and airy in the overall presentation. You’ll get more micro-details and resolution with the SM4, and they are a much better mid-volume set since the vocals and uppermids can be a bit too pushed back on the KE4. However, if you want a fuller sound and are open to cranking up that volume knob, then the KE4 is much more immersive with a heavier and better textured low-end, and just more unique and special.
vs CKLVX/PULA
But speaking of a “special” tuning, we gotta talk about the CKLVX and Pula. Compared to those 2, the KE4 is actually fairly similar when it comes to the vocals with all 3 lacking a bit of power and final extension, but still relatively well extended and aren’t shouty with the main difference being that the KE4 isn’t as airy and light as the CKLVX/PULA.
The KE4 doesn’t have that dreamy feeling of the CKLVX/PULA, but instead it’s more grounded with more depth, and it’s more natural in that sense. Basically, if you found the CKLVX/PULA to be too airy and sometimes sharp in the treble, then the KE4 fixes that with a smoother presentation with better textured bass, and a thumpier, deeper slam. Tech wise all 3 are around the same, meaning they’re decent, but nothing crazy like the Supermix4 or Quintet, and tuning wise they’re equally as good to me and switches depending on my mood.
vs AFUL EXPLORER
Then lastly some have been asking for an Explorer at mid volume, and the KE4s are pretty much that. Now, the Explorer will still be more intimate in its presentation, the vocals are closer, the stage feels more forward, and they scale better. Whereas the KE4 has more air which makes the stage feel more open, but because the 1K region is also scooped this pushes the vocals back, and creates a sense of distance on top of the air boost, which gives you an open sense of space that the Explorer doesn’t have.
Low-end wise the KE4s are an improvement overall from the texture to how deep the bass goes, and the overall impact, as well as having more overall detail, so basically what I’m trying to say is, if you like cranking things up, then the KE4s are a solid upgrade over the Explorers, less neutral, more open and bassy, but still very immersive.
Kiwi Ears KE4 Final Rankings (HIGH-VOLUME):
Tonality: A+/S- (8/10)
Tech: A- (6/10)
Overall: A (7/10)
Thanks for reading!
