I don’t think so. It might be worth it to try some to determine if you like them more but personally, I feel the normal CP100 are just fine. The CP100 PLUS might be even gummier/stickier so they seal even better but it might be too much for my inner ears to handle.
Getting Azla Xelastic vibes, will pass it up. Was just checking up amazon for some more spinfits. Thanks bro
Best tips ever (for me). They look like Final E tips but slightly longer and slimmer. I just can’t find with what I got them.
E-pro’s shape looks smilar but their tips not as flat like Final E and the ones I use
I cannot stand any sort of memory foam eartips.
What can you all recommend for me to try out in silicone for kinera nanna 2.0 Pro?
I actually bought some of my eartips from Amazon. jp. I started with the Azla sednaearfit, cuz they were only available on Amazon. jp, plus the official website like a year ago if I am not mistaken.
I have these eartips:
*Spinfit CP 100, and 145.
*Azla light, and normal ( long/short).
*Final audio E type
*Azla Xelastec
So now I am thinking to try the ePro EP01, JVC Spiral Dot++, Sony EP-TC50, and JVC Radius Deep Mount.
I like the SednaEarfit light short with the nanna, but lately they make my ears itchy after a short period of time and it’s very annoying.
I forgot to mention that I hate SpinFit eartips… I am kinda weird
Plus I didn’t like the Final E with the Nanna
So hopefully the ePro will be good with Nanna
Me too! Nothing else make a proper seal for me unfortunately.
Spinfits are my go-to.
Could not for the life of me fit the Finals on the Mele, but work great on the FH3’s. Then I wanted to see if they would fit on the most uncomfortable pair I have and with the red adaptors they fit great, now I can finally use these again.
If this is happening with the Xelastec tips then try the Crystal tips. They use a different material and should fix that issue.
Some people are sensible to soft silicone, and it makes them Itch. Do probably you’re having less reaction to the normal ones.
I never heard or looked at a Nanna graph, so please tell me, do you need treble taming and bass, or treble enpashis?
But I think the Crystal tips are for the TWS Earbuds, but I will give them a try
Thank you for your recommendation
I am using the BGVP W01 eartips… I forgot that I have them for a long time, and didn’t trying them till yesterday…
They are comfortable for me, so I will keep using them for now.
dude i tried for 15 minutes, thumb has carpal tunnel now, lol do you prefer them over Spins?
lol! I dunno what to tell you. I’m having a laugh.
I don’t. I prefer Spinfits always but because I have been very sensitive to inner-ear pressure, I’ve been trying to use different tips that don’t seal as well. Some days the Final E seal OK, other days they just fall right out of my ears. My ears are weird when it comes to tips.
But either way, if you want to get the E tips on Mele, I turn them inside out and hold the tip with my middle finger and thumb with my middle finger inside the inside out sheath pushed up against the tip stem. I line the stem up with the IEM nozzle and drive it right over the nozzle. Presto!
Final E > SF on Mele. Fite me.
THUMB IS ACHING!!
lol i feel like a little child reading your instructions lol, this will help. My ears go through that too, I def need to build it up like alot of you guys do to find perfect fit…
