It looked like silver to me when I checked this morning.
If you mean more U shape, M for sure! OG is more relaxed.
Thanks! ![]()
Will also go with EJ07m for the exact same reason
But first it needs to arrive in China and until then i am jumping back and forth on what design to choose or if i should just save the money and keep the lava shell, did not have any fit/resonance issues with it
They look great
3 sets you baller sweet!
We have the same red case, too haha. (I keep my flash drive in it, tho)
Don’t forget to add something about the tuning if you still want to change it.
Look hot ![]()
Thanks Nymz , i believe Joseph added the 3db Sub bass boost in the instructions I asked for a tad more high shelf if possible dont think 1 db going to effect the balance of the tuning if they can do as well.
Been great dealing with Joseph and LETSHOUER!
Should have landed there already ![]()
Please let us know how this turns out… Fingers are crossed ![]()
Hope you will get it back soon before mine finally arrives in China.
If it turns out well its definitely something to consider ![]()
The mistake still looks really sharp though lol.
Hey bro, Where’s the NSFW tag??
Sorry what happened ? Did my fat fingers hit something?
Nah, it’s just that ej shells are so hot some might call it soft porn ![]()
