The dealbreaker for me if the high output impedance of the a50, 4.7 for se and 9.4 for balanced is not ideal.
Reading the power drama drama on ASR with the designer just be aware that the power output listed in the specs only apply with a seriously hot DAC/source⦠ie 3V in for high gain.
Honestly power wasnāt too much of an issue in the first place imo, it drives things fairly well so I wouldnāt worry about it too much
Wanted to get some quick impressions here. Iāve read a bit of the back thread here. Iām looking to compare something against my Asgard 3. Iād been considering the Heresy for a bit, but now I am leaning towards the L30. Which would offer a more contrasting experience?
My headphones that itāll be pairing with are the Focal Elear and Elegia.
I also use a BTR5, just as an FYI.
Would also like to know how it compares to the A3. I wanted to upgrade from the LS to A3 but the L30 seems like a better deal.
Personally I think you are making a side grade moving from a liquid spark to a L30, whereas the A3 is more of an upgrade imo. The L30 is goIng to be more neutral than the spark yes, but itās only slightly more resolving and you loose some organicness and impact (along with a smaller stage but better imaging). The asgard 3 is moving up to the next tier of performance in comparison with honestly an overall upgrade in capabilities with a bit neutral warmer signature
Thanx MON, will hold out untill I can find a A3
I got an open-box but new L30 off eBay for a good price, so I decided to try it out as a preamp and spare headphone amp. My main headphone amp is an Asgard 3.
I didnāt test it for long but my Asgard 3 was noticeably better sounding to my ears. It had a smoother sound and more pleasing tonality. Comparatively, the L30 sounded relatively harsh in the way it reproduced electric guitars and drum high-hats. I also perceived better separation on the Asgard. Otherwise, the L30 seemed good. The sound is probably not for me though (at least compared to the Asgardās sound).
Iāll be returning the L30 because it doesnāt work as I had thought it would as a preamp (the preamp gain is too high for my set up - even at low gain things get quite loud at around 10 oāclock). Iāll be going back to using my E30 as a pre, despite me wanting a volume knob very badly.
Also, I really hate the L30ās pot. There is that āwiggleā people have complained about. I wiggle the knob clockwise and anti-clockwise a little and not have any changes to the volume. After being used to how smooth the Asgard knob is, I donāt think I could live with that.
INTRODUCTION
The second little device Apos Audio graciously sent me to review is the Topping L30. As a reminder from my E30 review, I am now enrolled in Apos Audioās affiliate program but have otherwise received no attempts from Apos to influence my opinion on the L30 or any other piece of gear.
The Topping L30 is a 139.99USD headphone amplifier in the budget, measurement-chasing category. And measure well it does! I wonāt go into all the gory details here and leave that to Aposās website where we see measured distortion numbers that approach 0 in all real-world listening situations and plenty of rated power (up to 3.5 watts per channel, in fact). Other notable features are the fact that the L30 is built around the same amplifier technology found in Toppingās top-of-the-line (top of Toppingās line, that is) A90 amplifier. The L30 offers 3 gain stages and can function as a preamplifier as well.
BUILD
There really isnāt anything to complain about with the build quality. The unit is a rugged metal box with a sturdy plastic faceplate. The volume knob has a fair amount of resistance. The switches have a satisfying click when they get flipped. It has a no-nonsense industrial design which I find pleasing and is a good aesthetic match to the E30 DAC (see my review here)ā¦which makes sense as they were conceived to stack together in the first place. One small nitpick is that the all-black model (the L30 also comes in silver) can be very hard to see in a darkened room. Letās play a little game called āFind the L30ā:
Yep, thatās my desk in a dark room lit by only monitor light and all the glowing electronic doohickeys you see. Did you find the L30? Probably. But you squinted, didnāt you? Admit it! A couple of times I did bump into things a little harder than I would have liked because I was fumbling for the L30ās pot in a room lit like that. Keep that in mind if youāre a dark-room listener or game a lot in the dark. However, that quibble aside I found the unit very easy and straightforward to use. The preamp feature is well executed too. I didnāt notice much a sonic penalty, if there was one at all, when using its preout. The preout and headphone out are also toggled with a switch on the front panel instead of having to plug or unplug headphones. That means you can leave your cans and your powered speakers/speaker amp/tube amp all plugged in at the same time and switch back and forth from the L30ās internal amp and its preout via that switch. Itās an interesting twist on that feature that some may appreciate.
SOUND
The L30ās initial sonic presentation is clean and smooth. And thatās not just and initial presentation, it stays clean and smooth throughout. Even when a track gets busy, itās clean and smooth. My experience with THX amps, which are also in this measurement-chasing game, is that they can be quite sharp and brittle in the treble. The L30 does not suffer from that issue and that helps a lot with this perception of smoothness. However, to my ear, this smoothness is too much of a good thing. Some detail and speed is sacrificed in this trade and at times the L30 sounds over-smoothed. There are a handful of situations where that over-smoothness can be a benefit ā really busy and poorly recorded metal tracks were some that I found ā but by-in-large I personally missed the detail and resolution that this smoothness appeared to cover over. Now, some may argue that this over-smoothness was due to DAC pairings. That is unlikely as I did the bulk of my listening with Toppingās own D10 DAC ā which is a measurement champ at its price point and also has that whole ESS sharpness thing going on. I tried the Schiit Modius and SMSL SU-8 as well. The Modius was slightly smoother than the other two but this smoothness was a feature of the L30ās sound with all of the DACs.
The sound signature of the L30 is also a touch mid-forward. I detected a slight emphasis on much of the vocal frequency range. This emphasis alone isnāt necessarily good or bad and is very much up to listener preference. I have an annoying hearing sensitivity in the 1KHz range so I noticed this forwardness but didnāt have much extra trouble with shoutiness as compared to using other amps. Treble has reasonably good timbre but is also where the L30ās smoothness is the most noticeable. The bass is a mixed bag. Whatās there is pleasant and not distracting, but there is also a surprising subbass roll-off. Simply put, the L30ās bass extension bottoms out before its competition does. Deep notes that I expected to hear in familiar tracks just didnāt get the oomph, authority, or control that Iām accustomed too even in this price range.
The L30ās spatial performance was reasonably good. The soundstage was wide and the imaging was coherent and it was able to maintain that width and coherence when tracks got busy. Neither feature was standard setting at the price point but nor was either feature significantly lagging. Overall, the spatial performance seems appropriate for a $140 unit.
HEAPHONE PAIRINGS
I found the L30 to be more sensitive to different driver types than most of its similarly priced competition. Overall, I think the L30 performs best with planar-magnetic-driver headphones. Iām not an engineer by trade so youāll have to accept my Physics-II level of understanding of alternating current circuits here, but my suspicion is the amplifier topology in the L30 delivers power more efficiently when itās driving loads that like more current (planars!) and delivers power less efficiently when its driving loads that like more voltage (dynamic drivers). My comments above about over-smoothness and bass roll-off were present on all driver types but to a noticeably lesser degree on my planars (HiFiMan Edition X V2 and Audeze LCD-2 revision 1 prefazor). My more price-appropriate Beyerdynamic DT880 600-ohm and Massdrop + Sennheiser HD6XX ā both of which are a bit on the bass-light side to begin with ā sounded even more thin and less authoritative on the L30 than other similarly priced amps. My biodynamic-driver based Massdrop + Fostex TH-X00 with Lawton cups suffered the most, though. On the L30 it sounded flat ā not a frequency response kind of flat, but a lacking-energy-and-vigor kind of flat. It normally sounds quite lively and detailed but it did not take well to the L30. Of my dynamic-driver headphones, the Focal Elegia responded to the L30 the best. The Elegiaās slight mid-forward signature actually jived well with the L30ās similar presentation. I think the L30 would be most at home powering a planar-magnetic based headphone that has a V-shaped or bright signature and is more aggressively detailed than average. I donāt have either on hand but I hypothesize it would be a good match for the Fostex RP-driver based headphones (T?0RP, Dekoni Blue, Modhouse Argons, etc) or maybe some of the entry level HiFiMans from the HE-4?? series, particularly a warmer model like the HE-4XX from Massdrop where the headphoneās warmth may mask the L30ās bass roll-off a bit. I think in the case of the Fostex RP driver it would bring their signature back toward neutral and might smooth out some their rougher treble in some areas. The HiFiMans can tend toward brightness and sharpness at times and the L30ās smoothness might balance that out well, too. A disclaimer on these hypotheses, though: they are educated guesses, not guarantees. If anyone buys such a combo and doesnāt like it, please no hate mail.
COMPARISONS WITH OTHER AMPS
Overlapping with this review I had the exciting privilege of having several other similarly priced headphone amps on hand. I have the JDS Labs Atom amp, Monolith Liquid Spark amp, iFi Zen CAN, and Schiit Asgard 3 in my personal collection and had the Schiit Magnius and Geshelli Labs Archel 2 GMR (review here) in for review. I plan to do a full-fledged shootout post with all those amps in the near future as theyāre all in the $99-199 range. Because of that future post I will not comment too much here; consider this paragraph a trailer. That said the Topping L30 is the measurement champion in this group. The Geshelli GMR, at least by Geshelliās in-house measurement claims, essentially match the L30 in distortion, signal-to-noise ratio, and SINAD measurements but claims something close to 1/3 of the L30ās rated power output. The Atom amp and Magnius come very close to those distortion and noise measurements with the Atom also only claiming about 1/3 of the L30ās rated power and the Magnius claiming about another 1.5 watts of rated power per channel more but also costing an additional $60 and almost requiring headphones that can be powered balanced. The Zen CAN is class A and the Asgard 3 is class A/B and are both more expensive. They technically donāt compete with the L30 on distortion measurements on paper, but the truth is all of these amps in this roundup measure well beyond the levels where any red flags can be reasonably claimed. As far as sound goes, the L30 has the smoothest and arguably most mid-forward sonic presentation of these amps. Whether that is good or bad depends largely on listener preference and headphone pairings. The L30 also shares that super-clean sonic presentation with the Atom, GMR, and Magnius. However, the L30ās bass-roll off is more pronounced than the bass roll-off of any of the other amps in this set and its smoothness also can come across as it being the least detailed. Again, whether thatās a good or bad thing depends a lot on headphone pairings and listener preference. Stay tuned for the full round-up post for more details on how all these amps compare.
FINAL THOUGHTS
The Topping L30 is a well-built and affordable headphone amplifier that easily wins the measurement championship at its price point. It has an interesting twist on the preamp/headphone amp integration I havenāt seen at this price and that works well. The sonic presentation is a clean and smooth but does come at the price of some lost detail and bass that rolls off more quickly than competing headphone amplifiers. The L30 seems to be most at home powering aggressive planar-magnetic headphones. So, if measurements matter to you, youāre on a budget, and you have or are interested in playing with aggressive planar headphones in the budget range, the Topping L30 headphone amp might be for you.
Thanks for reading and enjoy the music everyone!
Can you give us any more teasers, in particular around the Atom which seems to have held the crown previously?
On the 7th January 2021, reports about faulty L30ās causing damage to headphones were posted to ASR, Reddit and SBAF.
The cause of the fault are up to speculation, the nature of the failure suggests start-up current surge or electro static discharge to be the cause.
Edit: One more report on head-fi
Ufff really bad.
Something must have gone off electrically and caused an overvoltage.
Thatās the only thing that could have caused it.
We canāt do more than advise you not to use your headphones until we know which batch might be affected.
In addition, China is on holiday for the whole month.
thatās gonna hurt Topping really bad as it will start having everyone question their Chi-Fi product(s) from them.
Agreed. Posts like this should help keep them honest, though.
I have only read the initial reports that @mazeframe has posted.
The second worst thing is that it seems to be technically so that it inevitably destroys the headphones when switched on.
And Topping supposedly replaces the devices but does not replace the repair of the headphones.
This is strange for the Chinese, who think a lot of themselves and care that everything is done to their satisfaction.
But if you have already ordered from Aliexpress, you know they can do otherwise.
Maybe it is only a small part that is affected.
Where maybe just under 100 units are affected.
Maybe even less.
As mentioned, itās the holidays, the best thing to do if you have a unit that is affected. Use the time to send the amplifier to China during the holiday period, by the time it arrives they will be open again and can take care of the matter.
So that you can get an answer and a reaction more quickly.
And for those who have one, we can only recommend not to use it until there is clarity.
Above all, it would be annoying to have to buy new headphones during the Corona period.
I hope that Topping will solve the problem better and at least refund a part of the price for the damaged headphones, which would be better than nothing.
It is clear that even if a whole batch is affected and 500 defects have been reported, it will be difficult to please everyone.
Been lurking the forum for 2monthsā¦visiting 2-3times everyday. Finally registered to get involved with this thread.
Bought E30+L30 at the end of November and Iāve been really happy with them in conjunction with DT1990s (upgrading from Mayflower ARC Mk2 + K712s).
However, as the amazon extended return window closes for me at the end of January this L30 āissueā has me slightly concerned.
Considering to return L30, can I please have a recommendation for an alternative;
Looking at the ATOM-Magni 3+/Hersey-Asgard 3.
1990s arenāt too bright for me, will the Asgard be a significant change in sound signature to the L30?
I read that the A3 is warmer, will it quell the analytical nature of the beyers that Iām enjoying so much for gaming?
Thanks
P.S apologies if my question is inappropriate for this thread.
Hi. Welcome to HFGF. Iāll move your post to the official L30 thread when I get a moment and answer your question there. Iāll need a few minutesā¦
EDIT: Moved from āPSA: Topping L30 Damaging Headphonesā thread.
Hereās my take on a bunch of <$200 headphone amps:
The short answer is ānoā. The A3 is class-leading in its spatial reproduction. One of its standout features at the price point is how well it does soundstaging and imaging. It will actually enhance the 1990ās abilities from what youāve heard with L30 in that regard. If the A3 is more than you want to spend the Magni 3+ likely does that the next best, at least from your list.
The E30 dac is still a fine product as far as I know. So hang onto that one for now.
i saw your comment got moved. dont worry this isnt ASR where you will be murdered for asking a question about the sound of an amp. to be fair most dont have much difference however measurements cannot equal the human ear and brain as far as sound goes so amps to have a sound just know it is minimal at best and usually at high volume only. the asgard 3 is regarded as the better amp with more warm sound (not warm like tube at all just slight) and more power. so get it if you can afford it. otherwise the 3+ and heresy are identical maybe slight improvement to the 3+ being a discrete circuit with the schiit āhouse soundā if you believe in that. and slightly less power then asgard
Thanks so much to both WaveTheory & Gruntslayer for their rapid response to my query! (Sorry Iām not sure I could directly reply to 2 users with 1 post).
The information youāve given me is exactly what I was wanting to hear.
As previously stated I am very happy with the performance of L30, beautifully stacked with the E30 aswell. However, the āallegedā increased possibility of potentially damaging my 1990s which werenāt cheap leads me to edge on the side of caution and take the ābetter to be safe than sorryā approach.
Thanks again Lads, Iāll be proceeding to order some piece oā Schiit gear
