HiFi Guides Thread Playlists
I wrote a program that can scan any of our threads for Youtube videos and add them to a playlist. For me, it makes it much more convenient to explore all the stuff people have posted. Although right now SoundCloud isn’t supported. If enough people care, I will look into figuring out a solution for it.
YouTube provides the capability via their public API. Unfortunately, the way it works is users are assigned a daily allowable usage quota which means I can only add 200 videos a day. So it will take a while to create most of the playlists.
For those curious, here’s the code which is written in VB​ .NET. I highly recommend using Python instead if anyone wants to mess around with the YouTube API.
Program Code
'This code is only ran within Visual Studio since input parameters are hardcoded.
Imports System.IO
Imports System.Threading
Imports Google.Apis.Auth.OAuth2
Imports Google.Apis.Services
Imports Google.Apis.YouTube.v3
Imports Google.Apis.YouTube.v3.Data
Imports HtmlAgilityPack
Module Module1
    Sub Main()
        Dim StopPost As Integer = 36 'This must be the final post number from HTML\
        Dim StartPost As Integer = 1
        Dim ThreadURL As String = "https://forum.hifiguides.com/t/guitar-instrumental/17238"
        Dim PlaylistID As String = "PLZwSmpHx8xQnoz0vD1_lF6o65GNr2IAwt"
        'ONLY IF CREATING A NEW PLAYLIST
        Dim CreatePlaylist As Boolean = True
        Dim PlaylistName As String = "HFG Instrumental Guitar Thread"
        Dim PlaylistDescription As String = "Last updated on 6/19/2021"
        Dim IDarr(0 To 20000) As String, PostTrackingArr(0 To 20000) As Integer, VideoInsertStatusArr(0 To 20000) As Boolean
        ReadHFG(StopPost, StartPost, IDarr, ThreadURL, PostTrackingArr)
        Dim Cred As UserCredential
        Dim FS As New FileStream("C:\client_secret.json", FileMode.Open, FileAccess.Read)
        Cred = GoogleWebAuthorizationBroker.AuthorizeAsync(GoogleClientSecrets.Load(FS).Secrets, {YouTubeService.Scope.Youtube}, "user", CancellationToken.None).Result
        Dim YTservice As New YouTubeService(New BaseClientService.Initializer() With {.HttpClientInitializer = Cred, .ApplicationName = "YTserviceTest"})
        Dim PL As New Playlist, PLitem As New PlaylistItem
        If CreatePlaylist = True Then
            PL.Snippet = New PlaylistSnippet
            PL.Snippet.Title = PlaylistName
            PL.Snippet.Description = PlaylistDescription
            PL.Status = New PlaylistStatus
            PL.Status.PrivacyStatus = "public"
            PL = YTservice.Playlists.Insert(PL, "snippet,status").Execute
            PLitem.Snippet = New PlaylistItemSnippet
            PLitem.Snippet.PlaylistId = PL.Id
            PLitem.Snippet.ResourceId = New ResourceId
            PLitem.Snippet.ResourceId.Kind = "youtube#video"
        Else
            PLitem.Snippet.PlaylistId = PlaylistID
        End If
        Dim i As Integer = 0
        Do While IDarr(i) IsNot Nothing
            PLitem.Snippet.ResourceId.VideoId = IDarr(i)
ADD_VIDS:
            Try
                YTservice.PlaylistItems.Insert(PLitem, "snippet").Execute()
                Debug.Print("Video " & IDarr(i) & " Added")
                VideoInsertStatusArr(i) = True
            Catch ex As Exception
                If InStr(ex.Message, "Google.Apis.Requests.RequestError" & vbCrLf & "The request cannot be completed because you have exceeded your") > 0 Then
                    Debug.Print("Quota Limit Reached")
                    Debug.Print("Video Stopped on Post  " & PostTrackingArr(i))
                    Stop
                    Exit Sub
                End If
                If InStr(ex.Message, "Internal error encountered. [500]") > 0 Then
                    Stop 'Will try adding again
                    GoTo ADD_VIDS
                End If
                Debug.Print(ex.Message)
                Debug.Print("VIDEO FAILED TO ADD:  " & IDarr(i))
                VideoInsertStatusArr(i) = False
            End Try
            i = i + 1
        Loop
        Stop
    End Sub
    Sub ReadHFG(ByVal EndPost As Integer, ByVal StartPost As Integer, ByRef YT_IDarr() As String, ByVal ThreadURL As String, ByRef PostTrackingArr() As Integer)
        Dim QueueSize As Integer = 14
        Dim web As New HtmlWeb, PageHTML As String
        Dim doc As HtmlDocument
        Dim HFGpostArr() As String = New String(EndPost - StartPost) {}
        Dim i As Integer, HTMLreads As Integer, arr() As String, EndPostChunk As Integer
        HTMLreads = Math.Ceiling(CDbl(EndPost - StartPost) / QueueSize)
        Dim URLpostNum As Integer
        For i = 0 To HTMLreads - 1
            URLpostNum = StartPost + i * QueueSize
            doc = web.Load(ThreadURL & "/" & URLpostNum)
            PageHTML = doc.DocumentNode.InnerHtml
            If i = HTMLreads - 1 Then
                'EndPostChunk = StartPost - 1 + i * QueueSize + EndPost Mod QueueSize
                EndPostChunk = EndPost
            Else
                EndPostChunk = StartPost + (i + 1) * QueueSize - 1
            End If
            arr = SeparateHFGposts(PageHTML, StartPost + i * QueueSize, EndPostChunk)
            Array.Copy(arr, 0, HFGpostArr, 0 + i * QueueSize, arr.Length)
        Next i
        Dim Pa As Integer, x As Integer, str As String, k As Integer, j As Integer
        For i = 0 To HFGpostArr.Length - 1
            'If StartPost + i = 108 Then Stop
            x = 1
            Pa = 1
            Do While Pa > 0
                Pa = InStr(x, HFGpostArr(i), "data-youtube-id=""",)
                If Pa > 0 Then
                    YT_IDarr(j) = Mid(HFGpostArr(i), Pa + 17, 11)
                    PostTrackingArr(j) = i + StartPost
                    j = j + 1
                    x = Pa + 31
                End If
            Loop
            Pa = 1
            x = 1
            Do While Pa > 0
                Pa = InStr(x, HFGpostArr(i), "youtube.com/embed/",)
                If Pa > 0 Then
                    x = Pa + 60
                    YT_IDarr(j) = Mid(HFGpostArr(i), Pa + 18, 11)
                    If YT_IDarr(j) = "videoseries" Then Continue Do
                    j = j + 1
                End If
            Loop
            Pa = 1
            x = 1
            k = 1
            Do While Pa > 0
                Pa = InStr(x, HFGpostArr(i), "https://www.youtube.com/watch?v=",)
                If Pa > 0 Then
                    str = Mid(HFGpostArr(i), Pa + 32, 11)
                    x = Pa + 44
                    If j > 0 Then
                        k = 1
                        While PostTrackingArr(j - k) = i + StartPost ' code is for checking for duplicate ID's within the same post
                            If str = YT_IDarr(j - k) Then
                                Continue Do
                            End If
                            k = k + 1
                            If j - k < 0 Then Exit While
                        End While
                        YT_IDarr(j) = str
                        j = j + 1
                    Else
                        YT_IDarr(j) = str
                        j = j + 1
                    End If
                End If
            Loop
        Next i
    End Sub
    Function SeparateHFGposts(ByVal HTML As String, StartPost As Integer, EndPost As Integer) As String()
        Dim arr() As String = New String(EndPost - StartPost) {}
        Dim i As Integer, SearchStr1 As String, SearchStr2 As String, post As Integer, Pa As Integer, Pb As Integer
        For i = 0 To EndPost - StartPost
            post = StartPost + i
            SearchStr1 = "'position'>#" & post
            SearchStr2 = "<meta itemprop='headline'"
            Pa = InStr(1, HTML, SearchStr1) 'InStr(Pb, HTML, SearchStr1)
            If Pa = 0 Then 'Post numbers apparently get skipped when posts are deleted
                arr(i) = ""
                Continue For
            End If
            Pb = InStr(Pa, HTML, SearchStr2)
            If Pb = 0 Then
                Pb = HTML.Length
            End If
            arr(i) = Mid(HTML, Pa + 10, Pb - Pa)
            HTML = HTML.Remove(1, Pa - 20) 'neseccary to shorten the string because .NET string function can only index using 32bit integers
        Next i
        Return arr
    End Function
End Module
Here’s the first few. I will continue add more as I’m able to make them.
Electronic Music Thread
Japanese Music Thread
Guitar - Instrumental
Bass Gods Approved
